Port was not added to the aggregator as no port instance was part of LAG
Check for the correct port instance group ID. Else use a group Id that is valid.
Warning
Adding a port failed. portInst:%portInst% slot:%portIdslot% port:%portId% association with group:%grpId%
| Name | Type |
| portInst | uInt32 |
| portIdslot | uInt32 |
| portId | uInt32 |
| grpId | String |
